Reshaping objects
Tool
Tool set
Reshape
Basic
The Reshape tool reshapes an existing object by moving, removing, changing, or adding to its vertices. Change the length of objects (including dimensions), reshape single objects, or reshape multiple objects at once. Reshape polygons and polylines, including lines drawn with the Freehand tool (which are considered polylines). In addition, specify exact radius measurements for circular arc control points. The Reshape tool can also be used to reshape 3D solids, roofs, stairs, fences, railings, NURBS curves and surfaces, 3D polygons, and other objects. Some object types allow free-form reshaping using a 3D dragger.
The modes and functionality available for the Reshape tool depend on the selected object or objects, and the current view. See the following topics for more information.
2D reshape modes
3D reshape modes
Marquee modes
Transforming objects with the 3D dragger
Performing multiple reshapes
Reshaping 3D polygons
Reshaping NURBS curves
Reshaping NURBS surfaces
Converting polyline vertices from arc to radius
Reshaping roof objects
Reshaping stairs
Editing a fence
Editing railings
Editing cable networks
Reshaping the modifier path or boundary
